Coxwain
- Aug 14, 2017
- 46
Hi there
I have a 1986 mariner magnum 150hp 6 cyl motor
Same issue with the bendix spinning but not flying up to the top of the flywheel.
Likewise I have stripped the starter down, cleaned and lubed the bendix, but it still just spins.
I did not replace the brushes as they seemed good.
I did direct cable connection to trolling motor but couldn't get it to rise. Can the magnet and motor wear out? Could there be another electrical issue? I lubed up the bendix after I sprayed degunker on it to clean it up.
Should I just replace the starter or is there another option I should try?
