bennet trim tabs not working ?
canman
hi everyone , i dont think my tabs are working , if i lift the engine cover should i be able to hear them operate with the ignition switch on and push on one of the tab buttons ? thanks
oops!
Re: bennet trim tabs not working ?
you should be able to heat the motor (pump) working....it is the plastic covered box mounted on the transom.
if not....check the power
Don S
Tabman
iboats.com Partner
Canman,
How old do you think the system is?
Here is a link to a video that covers the system and basic troubleshooting: http://www.bennetttrimtabs.com/videoplayer.php?vID=10
Here is a link to a video covering Tabs Don't Move, No Sound: http://www.bennetttrimtabs.com/videoplayer.php?vID=13
Don S is on target about checking the 20 amp fuse on the orange wire that runs to the back of the switch. I would add to check both ends of the black ground wire that is attached to the pump as well as all the other connections to make sure they are clean and tight.
Here is a basic drawing of the system:
You can see the fuse and its holder, #s 34 and 35, as well as the black ground wire.
Below you will find troubleshooting you can print and take to the boat. Step 3 is a good place to start and if it is an older system check step 6.
Let me know what you find.
Tom McGow
Bennett Marine
Fluid: Automatic Transmission Fluid (ATF) any type. Hydraulic Power Unit is self bleeding, running the Trim Tabs up and down 3-4 times will purge air from the system.
Fuse: 12 volt system use 20 amp in-line fuse on positive. (24v & 32v use proportionately smaller)
Red= Port Valve
Green= Starboard Valve
Blue=Motor Forward (pump pressure)
Yellow= Motor Reverse (pump retract)
Black on HPU=Ground
Orange on Helm=Control Positive
Troubleshooting
1.If one side is not operating reverse hydraulic lines on the front of the Hydraulic Power Unit to determine if the malfunction is in HPU or actuator / hydraulic lines. If after reversing the lines symptom shifts to the other side the malfunction may exist in HPU. If the symptom remains on the same side, malfunction may exist with the actuator / hydraulic lines
2. Is the unit receiving a solid 12 volts? Low voltage will some times cause the solenoids to not open preventing the tabs from moving even though the pump motor is running.
3. Conduct the following test:
Remove the wires from the helm control and touch together as follows:
Operation=Reaction
Orange (+), blue, red= Port trim tab down
Orange (+), blue, green=Starboard trim tab down
Orange (+), blue, red, green= Both trim tabs down
Orange (+), yellow, red= Port trim tab up
Orange (+), yellow, green=Starboard trim tab up
Orange (+), yellow, red, green= Both trim tabs up
If the trim tabs function correctly for each wire grouping then the switch is at fault. Also note that any loose or missing screws on the back of the switch (whether a wire is connected there or not) can cause the pump to malfunction.
This test may also be done right at the pump by substituting a "hot lead" for orange. There is usually a connector to the wire harness within a foot or so of the pump. You want to check this connection for corrosion. You may wish to cut the connector off on the pump side and try the test on bare wires.
4. If you suspect corrosion on the wire connector near the pump, cut it out, test as above and reconnect using butt splices.
5. If you conclude the problem is in the pump, contact me. Bennett Trim Tab Systems carry a five year warranty.
6. Check to see if there is a relay in line on the wiring harness near the hydraulic power unit. If there is it is an Interrupter Relay (IR1000). It prevents the system fuse from blowing if you try to actuate one trim tab up and the other down at the same time. After you test as outlined above, try removing the relay from the wiring harness and retest the unit.(Note: the interrupter relay is no longer used in current Bennett Trim Tab systems and has been replaced with a Switches that "lock out" preventing a blown fuse).
tpenfield
I' have had several occurrences of the electrical connector coming loose or getting corroded . . .
So, check all of your electrical connections first.
canman
i checked all the wiring at the buttons everything looks good there ,i checked power to the orange wire i have power there , tomorrow i am going out to the boat and check the connections at the pump ..thanks .
