Bennet Trim Tabs
FreeBeeTony
A friend of mine has a 2002 Stripper w/ Bennet trim tabs. The tabs stopped working suddenly. The motor doesn't run when either button is pressed in either direction. I removed the switch from the panel and verified voltage on the center bar. Whern the switches are pressed I think I should only have voltage on 2 out of the 4 wires, there was voltage on 3 out of the 4 wires no matter which button I pressed or in which direction. I measured the resistance between the wires going to the motor: there was 17 ohms between the red and green wires and 0 ohms between the blue and yellow wires. I think the motor is bad. Any opinions?
BillP
Re: Bennet Trim Tabs
Try thehulltruth.com for bennet tab support. Tabman has a forum there and answers questions about tabs...and he works for Bennet.
