Bent Fins
I have a 1995 Ski Sanger, the bottom of the boat has (3) Brass fins or skegs.. that keep it from sliding when turing at high speeds. Two of the fins are bent slightly in opposite directions while the middle fin is straight. While driving the boat will not stay straight like a car out of alighnment. Does anyone know how to bend them back straight with out damageing the fin or the hull?
86 century
Ensign
Re: Bent Fins
The safest thing would be to pull them off.
you should be able to get them off fairly easy.
Then either repair or replace them.
Are they twisted or bent to one side.
Re: Bent Fins
The are not twisted only bent to one side. I thought about taking them off. I was looking at it and they are thru bolted to the hull but there appears to be some form of resin holding them there as well, probably to keep water out. I have heard you can bend them back with channel locks while still on the boat but haven't tried yet.
O-fishal
Re: Bent Fins
Boats dont handle like cars, I suspect they arent bent but shaped like that for a reason
86 century
Ensign
Re: Bent Fins
There is a good chance the sealant is 3m 5200 can be a real bear to get off.
You could try to bend them back on the boat just watch and listen for any signs of stress to the hull.
rallyart
Re: Bent Fins
The fins should be dead straight and in line. If you call Sanger they can help.
Your boat should stay straighter than almost any other from idle up to top speed.
