Bent skeg. Stringer 800.
Nivekt
My skeg has a bend in it that causes the boat to drift at low speeds. At high speed it is not noticeable. Is there a safe way to bend this straight or would adjusting the trim tab to offset the drift be my best method to cure this? Thanks.
Re: Bent skeg. Stringer 800.
Ayuh,.... That's not the cause of the low speed wander,... I/O powered boats just do that....
Nivekt
Ayuh,.... That's not the cause of the low speed wander,... boats just do that....
Well alrighty then. Thanks Bond-o. Move along folks, nothing to see here.
Celtichawk
Move along! Well I couldn't help but putting my 2 cents. Figured if you like to fix it even if it is not the problem watch this video.
http://www.youtube.com/watch?v=2SXe86h3Y_Y
There are others as well, you can have it cut similiar to the video and have someone weld a new piece.
Nivekt
Thanks for the info Celtic. It doesnt bother me any to leave it and I sure dont need another repair to throw money at that wont improve the boat any.
JARED T
it looks exactly like mine on my 40 hp johnson.i think the counterrotation from the engine causes a pulling to one side and adjusting the trim would fix the issue maybe.
