Bent starter bolts....
hohmanr
I replaced the starter on my 1985 350 mercruiser in 2001. It was one of those new gear reduction starters that look closer to a jet ski starter than something that has to turn over a v8..I have had to replace the starter bolts at the end of every year because they bend slightly enough to cause starter / flywheel misalignment...Dealer suggests buying a new starter when there appears to be nothing wrong w/ the $300.00 starter I purchased..Is this a widespread problem...???
quantumleap
Master Chief Petty Officer
Re: Bent starter bolts....
Try a higher grade bolt. Like at least an 8.
hohmanr
Thanks Quantum...I've thought about that but was concerned that I would end up w/ a cracked block rather than a bent bolt...Sounds like Mercruiser is using a cheaper grade of bolt...<br /><br /><br />Thanks again
Mount a front brace on it........<br />Something like the little "L" bracket on some 3.0ls.........<br />And grade 8 bolts.......<br />I'd be Worried about the Ring Gear........<br />Bad starter alignment will Really Tear it Up........
