ratdude747
- Sep 30, 2023
- 420
Question: My 1976 Starcraft Montego (Mercruiser 888, carbed 302) had a group 65 Car Battery in it. I pulled that battery to put in my truck, as it's obviously the wrong battery, like a lot of auto parts on the boat that didn't belong and have since swapped out. I'd like to know what suggestions are out there for a proper battery to put back in.
It has been previously converted to a PMGR-type starter (and unlike the rest of it, they actually used a marine rated starter!), so the cranking amp requirement is likely a lot less (based on past experience PMGR swapping one of my Ford trucks). The other electrical mods are a Pertronix Ignitor electronic ignition (points and ballast wire removal + new coil), 4 barrel carb swap (holley with choke heater, likely similar and rewiring the starting circuit with a fresh relay (as the previous setup wasn't quite right, direct driving the solenoid with the igntion switch
). There also is some aftermarket fan/heater thingy mounted under the console, but it currently isn't wired. Otherwise, everything is stock or stock-equivalent in terms of wiring (no added stereo/GPS/etc.).
