Best Battery?
bdenovio
What size/kind battery should I get to use as just a starter for a 40 HP Force outboard? I am using a separate deep cell for the accessories.
kenroy3
Re: Best Battery?
Concentrate on getting marine batteries for both applications. Unless you have a very hard-to-start motor or run alot in sub-freezing weather, the size is not very relavent.
The marine batteries give you the robustness needed to survive all that shaking and pounding that tends to break plates loose.
roscoe
Re: Best Battery?
A marine starting battery in size 24 or 27.
With a minimum of 450 cca (cold cranking amps)
or 550 mca (marine cranking amps)
bdenovio
Re: Best Battery?
Thanks ! A dual purpose marine battery would work well then, or go for just the starter ?
roscoe
Re: Best Battery?
If it is just being used for starting and navigation lights, get a marine starting battery.
The dual purpose is a compromise, why would you do that?
