Best Cold Starting Motor?
Robtile
I'm in the market for a new motor - between 50 and 60HP. However, I am a duck hunter and cold starting is critical. I've been thinking about a 4 stroke, but am worried that the oil viscosity in cold weather may complicate starting.<br /><br />I currently have a 55 HP Suzuki 2 stroke that is terrible cold starting - Any hints ideas or recommendations would be appreciated. I've seen some smaller Johnsons start when it is 6 below as I sat at the ramp and cranked and cranked until my battery went dead....aggrevating.
D
DJ
Guest
Re: Best Cold Starting Motor?
Rex,<br /><br />Four stroke won't be a problem. The EFI engines are the easiest to start cold. The new Suzuki 4 strokes are EFI as well as Yamaha.
rolmops
Hello.<br />In both 4-strokes and 2-strokes there are very good cold starters.What should count for you is the engine weight of a 50 or 60 horse on a duck hunter's boat, which because of its very purpose is not very large.Two-strokes still weigh less and you mentioned the name of a very good cold starter in your post...
NitroBoy543
heh, my ooollldd evinrude 7.5 starts in 2 pulls. its a 1955 :)
Allan19603hp
on the same note I have a 1960 3 hp evinrude started first pull of this fishing season and first pull 99.9 percent of the time i swear it starts better than most new motors.. This is just my 10 cents..
Pro Crappie Guide
Johnson and Evinrude are suppose to be the same...Suzuki...unitl now...Bombardier...<br /><br />So why does a Johnson motor out start a "Rude"???
Robtile
Thanks all - <br /><br />Does anyone know if Johnson makes a 2 stroke EFI motor in the 50 60 hP range><br /><br />Oh, and thanks to all you duck hunters with your 1950 motors ringing in to make fun of me....you must be the same guys with the boats that my retriever jumps in with when he hears their boats fire up while I'm still cranking away during duck season :)
cclemon
Robtile,<br /><br />As you know some engines are harder to start than others, especialy in cold weather. On cold days you can use a spray starting fluid. It doesn't take much and it can make the difference.
