Best Drain Plug Underwater LED lights??
codyray
I'm not to keen on drilling anymore holes than necessary on the stern of the boat. I have found a few companies that make high power LEDs. http://www.http://www.ebay.com/itm/B...item3ab81117c9
drain plug lights seems to be a a reputable and has an 8000 lum single lights
or would you recommend transom mount underwater lights
any experiences with these?
bruceb58
The drain plug is not the best location for underwater lights. If you properly seal, the installation should not be an issue using one where you drill a hole for the wires.
I use this one and its mounted right under my swim step so it illuminates the area right where my ladder is:
https://www.amazon.com/Lumitec-SeaBl...rds=seablaze+x
Not cheap but it is a fantastic light
diungerich
If you actually prefer the drain plug route, I'd find one of the better ones that is brass. And, of course, remember that your lower unit is right in front of it, so it needs a nice wide spread of light to look decent.
codyray
Not cheap but it is a fantastic light[/QUOTE ​
thank you for the info I was thinking of that also, I looked at the link link you put in, all the reviews are very good for that light.
codyray
Got it! thank you for the advice
