Yes, glass with poly resin is notorious for delaminating. When I was working on my 22, sometimes I was able to “peel” the glass off the wood like a sticker. However this is not a problem related to resin more than it is related to a sloppy/bad craftsmanship. Factories - to save time/money or doom the boat to obsolescence in only few years so you have to buy a new one or both -– put the wood pieces on and laminate over them when they are “dry”. What happens is that the dry wood absorbs the resin out of the laminate and you end up with resin starved laminate with weak bond.
If you coat the wood surfaces and edges with poly resin before laminating, you prevent this problem from happening and end up with much stronger bond. One coat will do and if you see any dry spots, just go over them.
