Best Lube to use for outdrive
lakenormangal
I need to get some grease for the outdrive on my Cobra. What is the best grease I should be using and I can I also use to grease the Bearing Buddies in my trailer wheels? Thanks!
wahlejim
Master Chief Petty Officer
Marine grade grease is more resistant to water, can be used on both the outdrive and trailer
Texasmark
Lubriplate Marine white grease is as good as it comes, has been used for marine applications you mention for over 50 years. Most auto parts stores stock it. Usually in a black and silver can.
