Best prop?
Capt dave 258
Greetings, recently purchased a 21ft pontoon boat with 19inch pontoons. Motor is a 80hp Yamaha, 4 stroke, carbed. Previous owner told me he put that motor on the boat and that it came off of a fishing boat. The prop is a 13x19 and needs replacing. Since the motor was on a fishing boat, I'm wondering if that's the correct prop for the pontoon or should I replace it with a different size?
As with all prop questions
The important ones
What is the max WOT RPM your motor is supposed to be turning
What is the max WOT RPM you are getting?
These are the important two
There are others in the prop sticky
Additionally, is your pontoon motor height set correctly?
QBhoy
As above needed for sure…but almost certainly, you’ll likely need a good few inches less pitch. Best get the numbers from a test though…before taking a stab in the dark at it.
