best scuppers ?
danmar26
The rubber flappers don't work so well on my 20' cuddy.I saw the rubber ball ones in Boaters World.How good do they work?Thanks.
Mike Robinson
Re: best scuppers ?
The best scuppers I have had experience with are like the ones found on rigid hull inflatables. They are like a rubber sock with an open end that has a lanyard so you can pull them up against the transom so the end is above the surface of the water. If you look at smart tabs on iboats store you can see them on the stern of the "Spartan"<br /><br />(click on trim tabs at the top of this page)
