Best sealant intake gasket ends?
Bansheex13
What is the best thing to use on the block part of the intake that will not leak?(4.3 liter chevy)
Don S
Re: Best sealant intake gasket ends?
Year?
Ayuh,.....
rtv Silicone....
Fishermark
Definitely the RTV silicone - throw the end rubber pieces away.
That's assuming you are talking about putting the intake back on - just smearing some silicone on a leaking intake will not work.
Bansheex13
1999 is the year,and I am talking about assembly,not fixing a leak. Any RTV sealant or should I use a specific brand or color?
Fishermark
I generally use the RTV black - but most of them work well for oil resistance. Just clean the area well and lay down a solid bead - about a 1/4" or so - and carefully install the intake. Be sure to coat the bolts with a sealant as well. Permatex makes a good product for that - keeps the oil from wicking up and leaking through the bolts.
I personally like to take a paper towel and wipe both ends immediately after installation. It looks better and makes sure the silicone is fully embedded in the gap.
JustJason
black rtv from permatex will do it...
personally i use three bond 1215.....
otherwise known as fujibond...
pricey, but good stuff.
