Best wax for UV protection?
ryanr623
What is the best wax for protecting the paint from oxidation due to UV rays?
jmarty10
Re: Best wax for UV protection?
I have used starbrite the last couple of years and like it. Was able to get it at the local true value.
cpubud
eveyone is going to like what they are using or they would not be using it
642mx
So true! I use Meguires, and I like it. ;)
To the OP, any wax will help keep the UV's off the gel, but you need to wax often!
dockwrecker
Wax or polymers are a sacrificial layer by design. UV, salt, dirt abraision will take the best of them off in 6 months at best. The best route is a good deep cleaning buffing to get the surface flat and free of oxydation and a strict regimen of waxing to protect the surface. Once it gets away from you, you get to start over. A good full cover will help reduce oxydation while in storage.
Nothing topical like wax or polymer truly lasts very long, the key is regular application over a maintained surface.
