Best way to check tachometer for accuracy?
arejaye
What’s the easiest, yet best way to check a tachometer? I have a Volvo Penta 5.0 I/O and I suspect it is now reading accurately.
Can these be adjusted/calibrated?
Are there settings one these?
alldodge
Have not found any that could be adjusted
Can get a hand held tach and most these days are photo electric
Can use a advance timing light because most have a tach reading. If the motor is EFI, can use a scan tool to read what the ECM is seeing
Even some multimeters have an inductive pickup which can be used to read rpm
