Best way to clean a gear lube monitor
summerwind1991
Got some green 'gunk' at the bottom of mercruiser bravo 2 Gear Lube monitor, what's the best way to clean this crap out
tashasdaddy
Re: Best way to clean a gear lube monitor
post in the i/o forum, for better results.
Chris1956
Summerwind, Remove the rmonitor container and use some solvent (acetone, paint thinner, gasoline) to loosen and remove the gunk. Make sure it is dry and then reinstall.
