Re: best way to clean a SS prop
for corrosion (suface oxidation), muratic (sp?) acid, carefully applied and rinsed does a fine job. Don't let it set on there, use rubber gloves and soak a rag to wipe where you want and rinse quickly.<br />For polish, the greatest stuff I've used is called "BEST" for metal polishing...work it the same as you would wax your car.....mirror finish.<br />If it's just grime from exposure to the elements, just use the polish...
