Best way to remove silicone from gelcoat without damaging it??
SSSuper83
I removed my swim platform and I am changing to a smaller teak unit. There is a TON of old silicone left on the transom and I need to get it cleaned off..whats the best way to remove it without damaging the gelcoat?
Home Cookin'
Re: Best way to remove silicone from gelcoat without damaging it??
scrape with a plastic scraper then use acetone
SSSuper83
Acetone I assume works better than laquer thinner?? Laquer thinner softens it but doesnt remove it...
arks
Denatured alcohol.
foodfisher
Denatured alcohol.
+1 Scrape it down real thin. Then rubbing with the alcohol on a rag will cause it to ball up and fall off.
Home Cookin'
Acetone and alchohol are about the same in this application, but thinners can sometimes leave an oily residue.
wca_tim
there are a couple of debonding products that work very well for taking silicone and even 4200 / 5300 off gelcoat. they're expensive, but work...
dan t.
soak with varsol, scrape off, then a final wipe down with brakeclean
jkust
They sell silicone remover at any home improvement store. It it like 3 dollars and looks like a tube of elmers glue. I use it on my shower every few years when I recaulk. They also have very effective plastic silicone scrapers. Of course the fiberglass is a little different between a tub and boat so you'd have to test it on a spot first. I'd try that first since it is so effective and cheap. I wouldn't hesitate to try it on my Chaparral if I had a reason.
