- Mar 8, 2009
- 42,891
Dated August 2015, bought 2 years ago (2018) so it was 3 years old when purchased
My Rinker
Removed the belt driven fuel pump and raw water pump assembly at the end of last season. Rebuilt the fuel pump side because found it started to leak last week.
I buy Merc brand new raw water pump kits (46-807151A14), which include impeller, pump housing, stainless plate, bolts, O and quad rings. There is no way I need the bolts but it comes in the kit
Just bought 2 new kits (Dated June 2019) this year for use in cruiser end next season
Now the issue; yes I know, will he just get to the point
Dropped boat in the water and did not make it to the slip before it was over heating. Tied up to closest dock and spent the next 2 hours finding out what happened. The new (NOS) impeller came apart in pieces
So I replaced the entire unit with a 2019 unit, finished the idle over to my slip
Findings during repair
When assembling first pump it was harder then normal to get the impeller in the housing. Also when pushing the impeller on the pump shaft that to needed more pressure to push it all the way on
Newer pump assembly impeller bent easier (not easy) and slide right on the shaft with not issues
The inside of the housing removed showed some burning but that was expected do to no water flow
If I ever find one that is harder to install in the pump again, it will get tossed in the trash
My Rinker
