Just got this 1985 BF100 motor. It fires right up but seems to get very warm quickly. I checked the green oil light but it seems to be burned out (can't even get it to light up with 12v attached). However, with motor running I get a 12v reading off of the wires leading to the light ( I assume the light should be on when running normally?). It might need a new impeller but it did pee pretty well for a while (is there a thermostat on this model? Should it pee right away or after it warms up?). Is there also supposed to be an alarm buzzer? Couldn't find it.
Is it oil pressure? Not enough water through the impeller? Do they run pretty warm normally (makes sense with a thermostat)?
Thanks, Jeff
Thanks, Jeff
