roehrle
- Apr 14, 2015
- 21
It appears to me that there may be a problem with the fuel pump 435352. I had a problem with a pump pre 2009 that had the check valves pop out of their housing and it happened again in a pump purchased in 2009. It seems mighty strange that two pumps that I purchased both popped the check valves when the 3 bought before didn?t. I could see one check valve to pop but two ??? I tried getting a check valve out on an old pump and it took me several minutes using an ice pick to remove the retainer plate off. What could cause this to happen on a pump that delivers less than 2 PSI ?? It is also strange that Evinrude has stopped making this pump without offering a replacement.
Surely Evinrude is aware of this problem, why are they silent?? I have written several forums about my problem and have not received an answer. It is my understanding that several different motors made by Evinrude & Johnson use this pump in 9.9 hp & 15 hp motors. I think the very least Evinrude could do is to offer a replacement part after making a s******* part.
