big prop
peacekeeper6
i just bought this big *** prop not realizing the size, it is larger then the exisiting one, will this hurt the engine/drivetrain at all if i use it?
Dunaruna
Re: big prop
It'll hurt if you drop it on your toe :p <br /><br />What size is it and what size did you have before?<br /><br />Aldo
peacekeeper6
Re: big prop
lol, hum, i dont know exactly where do i measure from?(new to boats)
vipzach
Re: big prop
there should be a number on the prop, usually towards the back. It should be stamped on there, may have to look around a bit for it.
Haut Medoc
Re: big prop
Generally speaking, most engines need to be 4200-4600 RPM @ WOT. Anything under 4200 & I would say your prop is too big. How does it compare to the old propeller performance wise?
