bigfoot prop help will this fit
dannyman3
i have 60 hp bigfoot the prop part #48-77338cl-11 i found and bided on one on ebay the part number is 48-77338-11 both have 15 spline and 11 pitch i dont know what the cl on my part number means i was told the one i bided on is for 1inch shaft 15 spline is that what i have i hope so i know the reg 60 was 13 spline mine is the bigfoot 15 spline
Dunaruna
Re: bigfoot prop help will this fit
The 'C' indicates extra cup, specifically made for pontoon boats (ideal for a bigfoot). Don't know about the 'l'.
dannyman3
so that prop with the same part number but with out the c will it work it is on a pootoon
Dunaruna
The genuine bigfoot props have a beefier rubber hub but the standard prop will fit and work.
Silvertip
If you are certain you have a big foot lower unit, then the prop will work. Standard (non-big foot) Merc 40/50/60 HP lower units have a 13 spline shaft while the big foot lower unit is the same as the 75 & 90 HP motors which have 15 spline shafts. The standard gear ratio is 1.83:1 and the Big Foot is 2.33:1. Therefore standard 40/50/60 HP and big foot props are not interchangable. They are actually much different diameter as well. More information than you probably need but this is common question.
