Bilge blower hoses
Jersey Guy
i recently purchased a 2000 Crownline 266br with a 7.4 MPI.
I have bilge blower hoses on the port side of my boat. The starboard side has the transom vent but no hoses leading to it.
How should it be set up?
garbageguy
Hoses (plural) on the port side? Tough for me to be sure without being at the boat, might be OK. Offending vapors can accumulate in the lower part of bilge when boat is not at cruising speed (assuming all venting set up correctly). Blower is intended to generate that ventilation when boat is not moving through the air briskly (at "cruising speed"). Blower hoses are part of that system.
Ayuh,.... The forward facin' clam shell blows fresh air into the motor box, 'n the aft facin' clam shell should have the blower, 'n it's hose suckin' air outa the bottom of the bilge,....
Jersey Guy
Sooo,
being a landlubber, do I need to add a hose or two on the starboard side?
wellcraft-classic210
Master Chief Petty Officer
Its more of a height issue - as long as the suction intake is near the bottom of the Bilge to pull out fumes that are HEAVIER THAN AIR you should be OK.
On a larger boat with 2 fans they often do have 1 on each side but on a boat with 1 intake either side is OK.
A few inches from the very bottom to keep the intake above any water that can collect in the bilge is OK
garbageguy
Sooo,
Possibly not. Bondo added some very practical info in a few simple words, as usual...
Consider opening the engine hatch for a once over (using nose too), before starting it every time
Lou C
From Chapman's....I have mine set up this way....
thumpar
Crownline's don't have cowls or vents like that. On mine it is 2 intakes on the side and one exit just above the swim platform on the back. On a 266br the side covers should have the intakes behind them.
