Bilge Blower Install
sinkn-feeln
I've hit the search function, but have not found quite what I'm looking for.<br /><br />Can anyone enlighten me on a proper bilge blower installation.<br /><br />Thanks
crazy charlie
Re: Bilge Blower Install
The install can be done any way that is easiest.the important things are that you route one hose to discharge(preferrably through a vent) and the other hose which draws air should be in the deepest part of your bilge area to evacuate any fumes or gasses. charlie
chris in va
Well, I'm not sure about putting the hose in the deepest part of the bilge. If water builds up in there, well...<br /><br />Rather, put it next to the engine, but not at the bottom. You don't have to screw down the blower or anything, but it helps. Rule makes better blowers than Attwood.
sinkn-feeln
Thanks guys, I wasn't sure about location of suction hose.<br /><br />Todd
