Bilge Blower
TyeeMan
Master Chief Petty Officer
So I've had 3 I/Os over the years, all of them aluminum FWIW. One of the 3 boats had a nice quiet bilge blower. The other two including my current boat, it sounds like the blower is going to vibrate apart.
Is there anything like a higher quality bilge blower? If so could someone recommend one?
I appreciate any info.
JASinIL2006
I was in the same position about a year and half ago, and I never found a 'top of the line' blower. Most of them look like what I bought (a 'Seaflo'), down to identical plastic housings and identical specs for CFM, motor, etc. I assume there are one or two companies that make most of them and the units just get rebranded.
Anyway, the Seaflo unit I bought isn't whisper quiet, but it is substantially better than the one it replaced. I'd give it a qualified recommendation.
I cant hear my blower over the "Potato Potato Potato" of my exhaust. my last batch of blowers came from Worst Marine as I needed them on a sunday. same as the attwood I replaced.
alldodge
Not sure you can find one real quite, they need to move a lot of air. My Formula also has Seaflow
I run them till the motor is running, then I turn it off
H20Rat
How is it mounted? Might be turning the fiberglass into a resonator if it is solid mounted. Try some rubber isolator bushings when you mount it.
TyeeMan
The transom of my boat is aluminum outside with a big thick piece of marine ply on the inside. The blower is mounted to the plywood, but I'm sure the aluminum of the boat resonates the sound.
On a different boat I could here the air blowing noise, no vibration. I was totally fine with that. This boat, I can hardly hear the air blowing but boy oh boy that sucker has a vibration to it, , or something.
I thought about finding some vibration isolating mounts, but there's got to be some blower somewhere that is just quiet all by itself.
muc
"Retired" Association of Marine Technicians...
https://www.iboats.com/shop/blowers-jabsco-legacy-imf-3183.html
Most high quality boats use a squirrel cage blower because they last longer and are quite a bit quieter.
I have converted a few boats for customers that feel safer running the blower at all times and don’t like the limited life span and noise of an in-line blower that most smaller boats come with.
If you search a little, they can be found that accepts a hose on both ends.
TyeeMan
Say now, I like those squirrel cage fans!! I'll have to give one of those some serious thought.
I don't run the fan 100% of the time, especially when on plane. At idle speeds I cycle it on and off, but man it's still annoying.
Thanks for all the tips!
