Just bought a '78 champion boat put a hose to the boat and turned on the bilge pump to make sure it worked. no water was pumped out. Here is what I have trouble shooted so far and my insight:
- turned on bilge pump put ampProbe on line going to pump, .12 amps being drawn...kind of tells me pump is shot.
- turned on aerator same amp draw as bilge pump reading. no bubbles coming into live well.
- found pump behind gas tank.. weird but it looks and feels like pump is being used for bilge and for aerator. This does not make sense to me. Maybe the previous owner wired the bilge switch to aerator pump to make it seem like the boat had a bilge pump. followed hose from aerator pump and it looks like it is going to livewells
found a plug that fits into aerator inlet (right by the drain plug). what is the deal with this.
boat has two ports on the side... i'm assuming for the livewells. one had a plug... again why?
My next move is to remove the aerator pump and get manufaturer info.
Any suggestions would be greatly appreciated as I'm new to boating.
