ntroisis84
- Jul 26, 2012
- 2
I found out my bilge pump stopped working when I almost sunk my boat. Apparently I didn't winterize properly and a freeze plug came out after about 10 mins on the lake. Luckily no crack in the block. Didn't know where water was coming from so I was just sucking it in trying to get to the dock. I decided to get a new pump after testing and seeing I was getting 12v to the pump. I also decided to get a float switch since I leave it in for the summer. I hooked up the new pump and tested the float switch and the pump worked. However when I use the manual switch at the helm it does not work. I retested at the pump and did not have power from the manual switch now. I hit the circuit breaker and I have power to the pump again. As soon as I turn on the manual switch it flips the breaker again. I tested the old pump on the auto switch and ends up it works just fine. I'm thinking I have a wiring issue, switch issue or circuit breaker issue but have no idea how or what to test. Any suggestions? I have an 03 Chaparral 215 if that helps
