l008com
- Jun 14, 2007
- 762
So, since this boat was new some 25 years ago, this is how the bilge pump was set up. The hose comes up from the pump, through a hole, and into the area in front of the motor. That area has a small hole that slowly drains the water.
See Below:
But woudln't it make more sense for the water to come out the side of the boat, where it wouldn't get stuck in a 'holding area', and instead would flow right out into the body of water? Like near the left side of the red stripe in this picture?
Assuming the answer is yes... What kind of adapter or valve do I need? I assume some kind of plastic insert that you insert into a drilled hold, probably that you glue into place, then clamp the hose on to with a hose clamp.
See Below:
