DALOW
- Aug 21, 2012
- 14
Boy, I don't fully agree with the video I just watched on this website. It was the video demonstration on explaining how an airlock happens in a bilge pump hose.
It was about Rule bilge pumps and avoiding dips and sags in your discharge hose line.
The air lock they created was because the hose went back down, even to or lower than the pump impeller. This I agree is a problem and you should avoid this situation.
However, the problem is; they stated that the hose line should go continually up until it reaches the through hull fitting. A much better approach is to have the line go as far up the gunnel or transom as you can go before turning around and going down to the through hull fitting. There should be a fastener at the high point of the line so it stays where you put it.
Without the high transom loop, a hole in the boat is effectively introduced at the level of the through hull fitting. In other words if you are sinking or keeled over as far as the through hull fitting, you will now have an additional way for water to enter the hull. This is exactly what you don't want.
With the high transom loop, the additional hole in the boat is effectively the peak of the transom loop. This is critical in sinking or swamping situations.
I realize that if you get to the place where water is enter the through hull fitting you are in trouble anyway, but you do not want to amplify the bad news by introducing an additional hole in the boat at the most critical time.
This is might be a small point during a nice day but of critical value if you are sinking.
For a second opinion check out http://www.yachtsurvey.com/bilge_pumps.htm . Between him and his father they have been surveying boats for decades. I have no affiliation with this guy I just have a lot of respect for him.
Thanks for hearing me
Doug
Doug
