thedukeryan
- Jul 21, 2009
- 298
I installed a new float switch the other day and have a few questions. First off the pump appears to have the +/- hooked up in reverse. I know this shouldn't hurt the pump but it seems to me that it would cause the pump to bring in instead of out
With that said it functions fine so I was curious if maybe the wires are just marked wrong or do pumps work in either direction? The next question I have is about the float switch. I have it set up so I flip the switch on the dash and tehn the float switch takes over from there. In other words the float switch does nothing unless the bilge pump switch is turned on. The bilge pump does nothing unless the float switch engages. Hope that makes since. What do you guys think of this set up? Should I rewire it so the bilge switch turns on the pump wether the float switch engages or not and then wire the float switch so it turns on the pump even if the dash switch is off? All this leads me to my last set of questions. Can the float switch short out or cause my pump to short out if I have a direct connection between the float switch and pump? My concern is that if Im cruising and the float switch is jumping up and down it will cause my pump to constantly turn off/on each time the switch jumps up. Hope that all makes since.
