I do know some wiring. But this has got me! Pump worked before putting into water. Took on some water, but pump did not work. Got home and started checking. Well it blew 5 amp. fuse coming off batt. switch. Horn, assc., etc. nothing working. replaced fuse, every thing fine. BUT, now my bilge pump runs all the time. Even with the batt. switch turned off. The light on the bilge pump stays on, with batt. sw. off. had to disconnect plug to pump to keep from running, also unplug switch. cannot understand how pump can run with main batt. sw. turned off?
