Re: bilge pump wiring
There is nothing special about this but some folks do some "creative" wiring so we can only tell you how it "probably" should be -- not what you actually have. Float switches typically have three wires. Manual (switched +12v), hot all the time, and ground. You didn't provide wire colors so you need to identify those. Black is typically ground.
1) Float switches have one wire that connects directly to battery. This is the hot all the time feed which allows the pump to run if water rises far enough to activate the switch when the boat is not attended and the console switch is turned off.
2) Each pump has a ground wire. That wire needs to connect to battery NEG or a ground buss if you have one.
3) The console switch normally when set to ON or MANUAL bypasses the float switch and therefore powers the pumps. You may have two switches since you have two pumps. This is important because if water is high enough to reach the lower pump but not high enough to reach the upper pump, if both were powered by the same switch the upper pump would run dry. Maybe a problem, maybe not. Therefore, power from the fuse panel goes INTO the switch. The OUT side of the switch feeds the pump. If both are wired to the same switch then the third wire from the pump would be the one to connect to the switch.
