bilge pumps
hyspenc
Hi guys .
I am putting a new floor in a 1984 smokercraft 14 ft aluminum fishing boat.
i removed the old bilge pump and submergible switch and livewell pump.
would like to keep the live well but was woundering is there a better way to hook a pump up that wouls fill the well and aerated as well i threw all the old crap out and now i am just trying to figure it out .
Bilge for sure i got that .
Live well not to sure .
there are 3 holes in transom one is main drain the other was inlet for live well and the third i assume is drain after you bring it a shore just a step in the right direction or product info would help me out lots thanks
mike_i
Ensign
As long as you have a live well pump and keep it running you're aerating the water as well. Post a few pictures of you holes. Your holes/drains should be the live well, bilge pump discharge above the waterline and the normal "pull or unscrew the plug" bilge drain.
