doug glass
- Apr 1, 2009
- 41
i know i'm not the first but my bimini does not want to fit correctly--i have a 1987 bayliner capri 1700 cr-- i bought a westland bimini from iboats that i looked up according to year and make of boat-- i put the frame and top together per instructions and when time to mount to boat the frame will not go inside of the side glass--too wide--if i try to bend it, the ends of the frame will stick way to far in the boat to attach-- i thought about mounting to outside of boat under the glass but the swivel mounts are screwed from inside out--so i would not be able to mount frame once mount is in place--i have e-mailed westland and iboats but i have always found sound advice from this group-- i'm thinking only option to do it correctly is to shorten the center bows and try again but not hurt warranty--any ideas are greatly appreciated
