suzukidory
- Apr 22, 2011
- 15
hi there i just replaced the mid section on my 80's mercury 50hp blueband electric start [power trim and tilt
and tonite was my first river test and things are not good i replaced all gaskets when rebuilt mid section i changed impellor and serviced engine the fault i have is
the boat starts idles no problem at all and can be run on splash muffs no problem it revs up nicely pumps water with a strong jet everything is fine on splash muffs
when it was in the river tonite when i start it up with choke or without when warm it doesnt matter if i cruise out of the marina at low revs the engine bogs down within 30 seconds and wont rev up at all
but if however i turn the key off wait 5 seconds and then resart engine and immediately go too full throttle flat out it will continue to run at full speed however as soon as i decrease revs it bogs straight away and cannot gain power without turning off waiting 5 seconds and then hitting full throttle again so my friend and i just came back from river test doing 35 knots for 6 miles on a restricted 5 knot speed limit river not good !!!
the engine itself ticks over beautifully and sounds perfect at full speed not missed a beat all night !! can it be anything serious please help
