I recently bought a used boat with a 1989 Merc, 130HP, 3.0L inboard. I couldn't get it to idle so I adjusted the carb mixture to get the boat to idle. This worked except it kept backfiring when I tried to accellerate. I adjusted the mixture again and now I'm idling at 1500RPM which is causing hard shifting and when I put it into neutral there is a lot of black soot in the water behind the boat. I'm wondering what is the proper way to set the carb mixture to be albe to idle/accellerate properly and why an I getting all of this black soot in the water when I go into neutral?
