Black with white stripe?
jgrisham02633
Just kicking things around in my head, what is the black with white stripe wire going to my ignition on 96 115 faststrike? Is it neutral saftey? Thanks
rodbolt
Re: Black with white stripe?
are you sure its white and not yellow and what part of the ignition ?
jgrisham02633
the harness is not actually in use yet but I am going through things in my head for when I get around to hooking it up, to answer your question-- the wire is #3 on the 6 pin connector that I believe goes to the switch?
jgrisham02633
oh yeh, it's definately black and white-- that plug also has black/yellow, yellow/red, purple/white, red, purple, all ignition colors I beleive.
rodbolt
its the ground lead for the kill circuit
rodbolt
somewhere along the harness. exactly what are you trying to do? the modular harness is all plug and play. cant mess it up.
jgrisham02633
I don't have a keyswitch or controls for that harness, I have to wire it to my old setup, I do want to use that harness however because I have the sys ck tach that goes with it, and my old harness is 30 yrs old.
