Blaring warning horn
chuknwind
I have a '01 40HP Tracker (Mercury) that has a constant blaring warning horn when the iginition switch is on. This started while out on the water and everything I checked seems to be working as suppose to. Even after several days on the trailer in the driveway, if I turn on the switch the horn start blaring. Mine is apparently sonewhere around the ignition switch, judging where the noise is coming from. Do I have a bad horn module or could it be more serious?
KcKiller
Re: Blaring warning horn
do u have a oil reservoir if so check the oil level.. sometimes the float in the tank has a magnet that comes loose and stay armed.. at least that?s what happen to me and from what I have heard...:cool:
joed
Could be a problem with the oil warning module.
