Just bought a 1974 Delta tri haul. It has a Volvo b30 engine with a Volvo Penta 270T. I am having 2 problems right now.
Problem1. I cannot get the throttle to work. I can shift and change the gears but the controls will not move the throttle cable. I can rev the engine at the carb. Is there way to see if the control box is ok? If I need to replace the controls will any other manufacture's control box work?
Problem2. The trim does not work. I can hear the pump spin but the ram doesn't move. I think I might have air in the system. Can someone help me with the proper way to bleed the system?
I looked for a manual for the motor and outdrive but the one advertised on this forum does not have a straight 6 cylinder listed in their description. Does anyone know where I can get one specific to this engine and outdrive?
thanks .... john
thanks .... john
