Bleeding air from trim/tilt
riverroad
I installed a Trim Motor on Nissan 90A. Trim motor works now, but engine is not being raised or lowered. I've added fluid already. Is it self bleeding or do you bleed by leaving the cap off that is used to add fluid and by raising the engine up and down? OR, is there another relief valve?
TOHATSU GURU
Re: Bleeding air from trim/tilt
What does the section of your service manual say about bleeding the system?
