bleeding the trim/tilt
Just rebuilt my 96' J200STLED johnson 200 trim and tilt what is the proper bleeding proceedures for the trim and tilt ?
rickdb1boat
Re: bleeding the trim/tilt
Fill the reservoir to the top(Until it comes out the hole). Replace the screw finger tight. Run the lower unit up and down several times. Check fluid and top up as necessary. Run it up and down a few more times. Repeat one more time and tighten the screw and you're done...
