I have a 200 HP Evinrude 1997 Ocean Pro (carbed fuel sucking monster) that the crankcase wall has a hole in. At first my decision was to rebuild what I have. After pulling the motor this weekend, I have other reservations and now am thinking about just replacing with a EFI or DFI. I could part mine out to offset the costs of the replacement motor. Here are my questions:
1) What would you do. $1500 in parts to rebuild or about $3k for used motor (EFI or would have to get good deal on DFI)?
2) How much could I get for mine in parts selling the main components on Ebay? Everything is good except the crankcase and the pistons seem worn. I would be selling as follows: carbs w/manifold, lower unit, power pack, coils (each), transom bracket, tilt/trim assembly, pivot bracket (think steering connects to) with midsection, heads, crank, rods, flywheel, stator, oil tank, starter, fuel pump.
Thanks.
Thanks.
