Block corrosion
Spike2450
Hi again!! easier one for you all this time!!
After recent experience of corroded manifolds and risers!!!
The main engine block is also cooled by raw salt water, does the block tend to get corroded as bad as the manifolds, what is the life span etc?
Re: Block corrosion
Short answer is,................... Ayuh..........
Some of the Guys who play in the Brine will comment on the "How Long" part.......
Here in the Sweetwater,......
Even the Exhaust Manifolds,+ Risers tend to last Forever.......;)
