block plug
letsgo19
I for the life of me cannot reach the starboard side block drain plug.Do you have to open both sides to get all water out?I can reach the plug on port side,exhaust plugs and plug on water pump hose.Also how hard is it to get thermostat off it's a mercruiser 5.0 220 hp carbed.And is it worth the trouble or should i just bring up to temp. then anti freeze through muffs.
Re: block plug
Ayuh,... It's Absolutely Necessary to drain ALL of the motor...
A 1/2 azzed winterization usually leads to a Brand New motor come Spring...
letsgo19
Re: block plug
So do i have to remove thermostat to get atf into block?And how in the world am i going to reach that block plug then be able to turn it?
Re: block plug
Ayuh,... I winterize by Draining the water... dry,... Air just Don't Freeze...
There's write ups all over the net,+ some up in the Adults Only section at the top of this forum explainin' the Antifreeze method...
as fer the Unreachable plug,....
Sometimes ya gotta remove things Other than what you wanta work on, to get where ya Wanta work...
I donno, I don't know your boat,... Boat Manufactures do their Best to make life Miserable for people like me, workin' n this stuff...
dingdongs
Re: block plug
some of the larger engines are a pain and unless your a stick insect.may need to remove parts and cutting an arm access hole may be a blessing in disguise as manifold drains are even harder & spark plug replacement too.both sides need completly draining to save mega probs next year.
letsgo19
Re: block plug
Beginning to think bringing engine up to temp then running atf through muffs is way i will go.Have a feeling i will create more problems trying to remove plugs than i want to.BTW is it true that thermostat doen't need to be "opened' because there is a "bypass hose"?
boat127
Re: block plug
you were giving good advice
remove the plug do what you got to do to remove it. i dont beleive in running antifreeze threw it and if i did i owul draing it completely first but its your boat/motor i'll post in the spring when you come whining about a new block
wire2
Re: block plug
There will be 1-2 quarts of water sitting in each side of a V8 block. If you choose to leave 1 side alone, and pump anti-freeze in, there's no guarantee that the a/f will displace all the water on that side.
If it's THAT hard to get at it, remove the exhaust manifold & riser, put a hose fitting in place of the plug, add a 2-3 foot hose with a plug on the end.
Or, better yet, install a quick drain/inject system like this one;
http://www.thewinterizer.com/
erikgreen
Re: block plug
For the rebuild of my boat I put in removable sides to the engine compartment, so I can get at all the drains easily.
If you can't get at it easily, take it to a dealer for winterization service that has a guarantee... if they do it wrong, you get a new engine :)
Erik
letsgo19
took advice
took advice
OK i got all drain plugs out but now i have another issue.The small chain that is attached to remote oil drain tube came off the tube,so now i can't pull it through transom drain hole.:mad:
Re: took advice
Re: took advice
Ayuh,... Did I hear you say, you wanta be a Boat Mechanic when ya grow up,...:p
Pullin' motors to change Sparkplugs is Not unheard of.....:rolleyes:
letsgo19
Re: block plug
So this being new to me,any advice on how to drain oil?Is it like a car with a screw on bottom of oil pan?
wire2
Re: block plug
The tube is connected to a fitting that takes the place of a car style plug. For that system to work, the actual plug has to be on the end of the tube, so you can open it after you get it through the transom drain hole.
Untwist a wire coat hanger, fish under the engine with the hook for the tube. Bring it up beside the engine and put the chain back on.
