blower when should I use it, mercury mercruiser celebrity
lenarw79
I had pontoon boat and last fall I bought Mercruiser Celebrity 87,260hp sterndrive alpha one. My Q is: how works blower and when should I use it
flipbro
Master Chief Petty Officer
Run it 4 minites be4 u start your boat and when going throw no wake zones is what's recommend.
ghunttwo
I agree with flipbro with the exception of run it at slow speed, At idle or slow speed you don't have enough air coming through the ventilators to produce good bilge fume evacuation.
Baylinerchuck
Absolutely you can. Just not necessary above idle speed as long as all the ducts are hooked up to the louvers.
I use my blower the entire time the motor is running
