That’s why i’m asking because I don’t know correct me if I’m wrong but I thought these engines were designed to run on lower compression 100 psi. I will probably just stick with my rebuild plan.
can someone please tell me if it’s OK to reuse my piston rods.
To answer your question specifically:
You have to inspect for signs of heat discoloration, uneven wear, or pitting on either crank journal, connecting rod crank bearings and connecting rod bearing holding surface.
Regarding the connecting rods themselves, keep an eye out for connecting rod caps being warped (those often show up when they are removed and you attempt to put them back on, where they won't align). When that happens, you're probably better off buying a good used connecting rod.
The biggest issue/problem at hand that should be considered:
You need to train yourself to know how to inspect the engine mechanic parts and check tolerances with the proper equipment. You've already got burned once, it's time to slow down and put the brain to work.
In a sense, you are going to have to put yourself through a self-taught marine outboard technician training course if you're going to do most of the powerhead rebuild/assemble work. There's no shortcuts.
Some of this you can do yourself, however a lot of it you will need to source out.
This is not like reading the directions on installing a TV mount and LCD TV on the wall.
You must do a lot of research, think analytically, and be willing to ask well thought out questions.
Right now your options are:
1. Send powerhead to be rebuilt by a professional who will always itemize list what was replaced/serviced and why.
2. If they are within local driving distance, send the powerhead to the professional and have them service/replace items that require machine shop work. That way you can pick up the parts and do the assembly yourself if you do it correctly.
3. Buy a remanufactured powerhead from one of the suppliers.
Any way you do the rebuild, you will have to research and determine what jet changes in the carbs will need to be made for an oversized motor.
