I took the head off of the right side of the engine and found that i had a blown head gasket. The guy i bought the boat from had been running it like that and the piston is toast and the cylinder is messed up pretty bad. Is it possible to replace the piston, hone the cylinder and use oversized rings to fix my problem? Has anyone else ever had this problem. The cylinder doesnt look really bad, just has some corrosion build up and light scoring. What are some other problems that might come up because of this and are there any other solutions to my problem. Would i be better off not throwing money on parts into it.
